What change does the sewing operation do to a B surface?
I am using UF_MODL_create_sew to sew two surfaces. But when I query the target surface for knots and control points using UF_MODL_ask_bsurf before and after the sewing operation I see no difference. So I am not sure if I have the right results.
Does sewing alters the geometry of the surface itself Or creates a new surface with the altered geometry apart from the initial surface ? Or it is the only the representation that is changed ?
Is sewing saved in the part as a separate feature or something ?
I am trying to understand the format in which a part is saved in NX file and how are all the features saved? Please point me in the right direction.
Thanks in advance for the help.
Wilson
