That depends upon the require humidity in the room. 22C with 50% RH corresponds to a dew point temperature of 11.11 and with 5% coil BPF, you will be in trouble. If the room required RH is 60% or above, that will work. Make sure that there is enough air flow to take care of the room heat load.
