MortenHansen
Automotive
I wonder if somebody on this forum can tell spot what theese adjustable hydraulic devices are ? (See pic):
The devices are inserted into a hydraulic block and looks like they are adjustable. Some numbers are written next to the devices on the hydraulic block with a permanent marker. Perhaps pressure ? Flow ? Looks like some calibration tags or something. The hydraulic block is fed by a double set of hydraulic gear pumps. It has a servo valve for flow control and theese are mounted under the block.
Could it be relief valves ?
Flow or pressure valves ?
Any hints would be appreciated !
Morten Hansen
Morten Hansen
