RussDav
- Apr 22, 2006
- 6
Has anyone else tried using WF4 on Windows 7 and noticed that it takes longer to generate a plot? If so, did you find a remedy?
The 64 bit RC and RTM of 7 produce the same results, about twice as long to generate the same plot as it takes on XP, 32 or 64 bit. I haven't tried the 32 bit 7 since I need to move up to 64 bit.
Running the Ocus benchmark, I see that graphics related things are lagging a bit on 7, but I don't see anything taking twice the time, even the plot and DXF generation steps. That makes me wonder if there is a config option that is affecting the plot generation. I do run the same configs with XP and 7 though.
On the plus side, I do think PDMLink runs smoother on 7 at least. Hopefully the graphics drivers will catch up to XP and improve this plotting slow down.
