It depends on what you mean by success. White cast iron is an extremely hard, cast material that when welded upon will degrade its properties. It is extremely crack sensitive because of the type cast structure. The only way I know is to heat this material to temper before welding. Unfortunately, if you do this you loose the benefit of hardened material.
