mfgenggear
Aerospace
- Jan 23, 2008
- 3,465
Please advise what this welding symbol means see attached
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
With gas backing, inert or semi-active (Nitrogen + hydrogen, which is fairly active even in small quantities) gas is generally meant.dik said:gas backing? just air or inert gas.
Sounds like you need to acquaint yourself with welders who know about clamps.ironic metallurgist said:The M cannot be Machining, because any joint thin enough to permit CJP welding on a square groove will be too bent out of shape to machine.
