Leo Baldwin
For some reason i have always been under the impression that you simply cannot weld nelson studs to top of a steel stud wall? I have a section of building where the interior bearing wall is done with light gauge 2x4 steel studs and will carry the weight of a concrete floor from above. All loading looks good. The connection has always been a no in my mind. Because the top track is too thin and welding to it would not work?
There are 1/8” diameter studs - not sure how common these are - typically requiring base plate to be 1 third of that. I see no code or installation guidance i can find…
