metalsmith
Military
welding of an austenitic type steel with a 309 lsi wire is causing a crack in the fusion zone. pre-heats are around 180c and post heat is around 220c for 8 hours. Welded parts are under vibration and shock stress. I'am told that introducing any other type of filler will cause a martensitic structure and therefore cause cracking.
Is there a Mig Wire better than 309 LSI
