welding in 1958
penpe
In evaluating the load capacity of a nozzle on a propane tank it appears that the weld strength of the connection could be a primary consideration. I typically use 0.928k per inch of 1/16" fillet weld for 70ksi electrodes for new welds, (0.3 x nominal tensile strength of weld material x effective area). The actual weld size isn't called out anywhere on the vessel drawings so I'm conservatively assuming 1/8" because the thinner of two connected parts is about 1/4" thick. What would be the likely nominal tensile strength of electrodes used in 1958?
I'd like to be able to report to the client that the 4" diameter nozzle is attached securely enough to the vessel shell (0.85" thick A212-B steel) to support a 5000 pound load. Without adequate info assuming a 4" standard weight pipe (4.5 O.D.) circumference is 14". 14 inches of 1/8" fillet weld with E70 electrodes good for 26,000 pounds, so 5000# seems not a problem, but need to be more specific.
I can't find much about weld strength in 1958.
I'd actually measure the weld size and type on the nozzle... I'm not sure what welding material was common back then, but in the late 60s, E60 series electrodes were common. Also weld strength is a function of the base material, too. Do you know what the existing steel is?
Thanks for that info, dik. The tank shell is A212-B 0.85" thick which I'm finding is 38 ksi yield strength, 70 ksi tensile strength (according to a couple of sources). The nozzle is called out as 4" diameter, material A181-1, 300# thickness. I've not yet researched what that means. My initial (hopefully conservative) assumption would be that it's standard weight steel pipe wall thickness 0.237". Please enlighten me if you know more about these materials, and how they might affect the weld strength! I attached a photo. You'll notice that there's also a reinforcement ring, which is called out as A212-B: 0.85" x 7 1/2". Thanks again.
 https://files.engineering.com/getfile.aspx?folder=2be18028-88b7-42f2-be34-7fa0fcc8a3d3&file=crop.jpg
I'm not familiar with the type of steel... but will see if I can get some info.
Catch the attached... based on Canadian Code. Modify as req'd.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1707924383/tips/Weld-Design_p3ewfj.sm[/url]
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1707924298/tips/Weld-Design_Prn_xgolnv.pdf[/url]
SA-1212 B was replaced by SA %15 and SA-516. As I remember grade 70 but could be grade 60.
Thanks... I'm not familiar with these materials... they are not normally structural steels.
A515 and A516 are common pressure vessel steels and common structural steel plate materials.
thanks...
