If it is arc gouged damage you have a little more work to do in terms of preparing the gouged surface for weld repair. Remove heat affected material before welding and perform surface nondestructive testing both before and after welding/blend grinding. If the gouge was mechanically induced, I would also perform a surface nondestructive test before and after weld repair.
