welding a built-up section
tolind
I'm trying to design a builtup section to solve an existing problem. I need to increase the moment of inertia for a roof beam for a monorail to be added. I've determined that if I add a 3X1/4" plate to the bottom of a W12X19 I get the properties I'm looking for.
I know that I need a lap joint fillet weld to attach but I don't know the size and the places I'm looking aren't spelling it out clear enough for me. I figured I'd use a 1/4" fillet weld. My max. shear is 8.5 Kips. A 3" weld both sides every 12" should work. Can anyone explain the design process to me?
Thanks.
You only need to weld to develop the shear at the section under consideration... then I usually weld at the end to develop the full capacity of the added plate. Can you weld the monorail section to accomplish the increase in section property?
Dik
"Steel Structure" by Salmon and Johnson, and "Design of Welded Structures" by Omar Blodgett are good resources. I am sure there are a host of other user friendly references out there that will explain the design process.
BTW, the maximum size fillet weld on the edge of the 1/4 inch thick place must not exceed 3/16 inch unless the weld
designated on the drawings to be built out to obtain full-throat thickness: AWS D1.1 Sec 2.3.2.9 (2) & 2005 AISC Spec for Steel Bldgs Sec J2.2.
Since this is for a monorail, will fatigue be considered? ref: D1.1 Table 2.4, item 3.4
The equation you want is the shear flow equation: f=VQ/I with which your results will give you force per unit length along the plane between your plate and the wide flange. You can look up the definitions of V, Q and I in any mechanics of materials book and most likely online as well. With the shear force per length, you can determine your weld spacing for a given weld size. You should also develop the full tension force at each end of the plate with a weld as dik mentions.
