Weld symbol callouts HELP!!!!!
griffisj
I'm using V19 and need help with the weld symbols. I need to bend the leader line on the weld callout. Is there a way to do that? And is there a way to have 2 leader lines to one weld callout?
Thanks!!
Jamie
press the alt key and click on the leader where you want to break it. then take the select tool, cilck on the black square and move it the way you want.
beside the command callout, you will find a command called 'leader'. you can click where you want the additonnal arrow to point to and the click on an existing callout where you want to attach it.
Fred
Thanks! That worked great. Too bad that wasn't included in the help menu!
Jamie
Jamie
It is !! - in Help just search for 'leader' and you should see (on V17):
Leader Command
leaders
adding
inserting vertexes
deleting vertexes
If you're new it's going to take a while to get to know some of the terminology used in Edge, then you know what to look for in help.
Good Luck
bc
