Hi everyone,
I'm in the middle of sourcing a 450 gallon 304L IBC (intermediate bulk container) on short notice to meet a fast pace project. In order to get the IBC made quicker, the vendor has presented the option of not removing weld slag to decrease the lead time. I understand slag to be residual flux that was fused together during the welding process around the weld area, and if that is true, then I would want the flux to be removed so that the passivating liquid is not prevented from having thorough contact with all surfaces. The IBC will hold ambient water and steam condensate.
So my question is can weld slag interfere with the passivation process? I have concerns that in the instances the hot condensate is directly discharged into the IBC without mixing into ambient temp water, that the hot condensate become an issue for those areas that weren't properly passivated due to the slag not being removed.
I would appreciate your comments on this matter.
