bluntforce
- Nov 1, 2007
- 4
trying to find literature for one of the welders in the shop to help him understand why he should not weld across the grain of 2x2x1/4 steel tubing. there are caster plates( 4 ea.1/8" thick 3"x6" steel) that is centered on the tubing and flush to the end, underneath the tubing. after I gave him a dwg of the weldment w/ specs indicating I wanted (3) 2" welds on both sides evenly spaced running paralell w/ the tubing, he elected to weld under the tubing ,across the grain. this frame is 3' wide and the casters are 10" away from support columns.the frame will hold appx. 700-1200 lbs.
any help would be appreciated.
