Weld calculations for studded flange on circular cover
timsch
192
I have a 40" blind flange, 3" thick that will have a 5.5" diameter hole bored offcenter, with a 4" studded flange welded over that hole with a 3/4" inner fillet and a 9/16" outer fillet securing the studded flange. Design conditions are 150psi internal pressure & 320F, all materials 316L.
I have been tasked with performing weld calculations. I am referring to UG-37,-40,-41 & UW-15,-16 and following L-7.4 as the closest example I could find.
I was able to find some information on a studded flange for this calculation in Fig. UG-40(a-1), but I am uncertain about certain values to use for calculations, specifically values for A_2 shown in Fig. UG-37.1.
Per UG-40(a-1), t_n=0. For A_2 = 5*(t_n-t_rn)*f_r2*t, I will wind up with a negative number if I have any value for t_rn. If I just consider the cross sectional area of the studded flange itself, based on the hatched section of Fig UG-37.1, I come up with around 50 in^2, but this is not how the area is calculated per formulas for A_2.
What am I missing?
Thanks,
Tim
EDIT: To answer my own question, I am (was) missing UG-37(b)(2), and I've been barking up the wrong tree. UG-39 does not mention weld reinforcement. I just need to find the section in the code that covers weld calculations for my application
UW-16(a)(2) refers to calculations required in UW-15. UW-15(a) refers to UG-41 calculations, which puts me back where I was when I posted above, needing to find A_2.
So, again, what am I missing?
What you're missing is that A2 is excess area in the nozzle wall available for reinforcement. No wall (tn = 0), no A2 (A2 = 0). Likewise ignore A3, A41 & A43, they're not there. Use A1, A5 and A42.
Your weld strength paths should look something like the attached.
Mike
 http://files.engineering.com/getfile.aspx?folder=9e119993-8263-4b96-9bcd-f22006622e76&file=Doc1.docx
Thanks for the response, Mike. I was going down that path when I posted right after the 1st (deleted post), but started 2nd guessing myself.
I've attached a drawing of my flange assembly, since it differs slightly from your attachment.
If I use A1, A5, & A42, it appears that I miss out on one of my welds. Is that not so?
 http://files.engineering.com/getfile.aspx?folder=2b4aca44-3468-438f-a165-475c9b555a1e&file=Untitled.pdf
timsch, my mistake, A43 should not be ignored. Inward weld is there.
timsch, I'd use weld paths as follows: W = (A - A1) * Sv as shown, Fig UG-41.1(b)
W1-1 = (A5 + A42) * Sv, A2 & A41 = zero.
W2-2 = (A42 + A43) * Sv, A2 = zero.
I'll admit, UG-41 is not my best thing :)
Mike
Thanks again for the input, Mike. I'll look at it with a fresh mind this weekend.
