We are performing a load rating on a bridge that exhibits significant corrosion of the steel webs near the abutments. There are several holes in the webs near the bottom flanges, the largest of which is 2" high, 16" long. I am having trouble calculating the shear capacity. I am uncomfortable using the reduced web depth for calculating a conventional shear capacity (reduced d x tw x Fy), but I also believe I should not give a capacity of zero either. Is there any information out there for analyzing such a case?
Thanks for any information.
