ichibansan
- Aug 20, 2001
- 13
Here's the situation.
A large base slab for a rectangular tank has been poured. The vertical dowels projecting out of the slab for the future walls have been cast, but unfortunately they have been improperly located such that they have 1.5" of clear cover as opposed to the specified 2" as required by ACI350.
Per the civil engineer, there is no flexibility with regards to being able to bump out our wall thickness; i.e., we can't simply tell the contractor to bump out his forms 1/2" on each side to compensate for the inadequate cover because doing so has an effect on the function of the tank that is undesireable in the eyes of the civil guy (specifically, the inside volume of the tank would decrease).
Obviously, it would be a huge task to tear out all of that mat slab concrete. Similarly, it's a pretty big undertaking to come up with some sort of solution requiring the dowels to be cut off and replaced with properly-located epoxied dowels.
So here's the question.
Is anybody aware of literature that outlines the application of a given surface-applied sealant that can essentially act as an "equivalent" thickness of concrete cover? ACI318 Commentary sectionR7.7 alludes to such a thing, but off hand, I'm not very familiar with what it would be.
Thanks in advance for your help folks!
