I want to know how I can waterproof concrete block from the inside.
I have a storm cellar that's about 10' x 15' underneath my house below ground level. The room has a poured concrete floor surrounded by concrete blocks. When the floor was poured, I placed a bucket into the floor, for a sump pump in case one was ever needed. Turns out I do. I installed a sump pump and it keeps the floor dry, however I would like to seal the blocks to prevent the ground water from entering. I can put sealant on the inside of the wall but I would also like to seal the blocks from the inside. I would like to drill some holes in the block wall above the area where I think the water is coming in, and pump some type of sealant into the blocks, and seal them from the inside. I am hoping someone has tried this before and could give me some suggestions.
