If the container is fully sealed and totally filled with water (no air) then you might just be able to get water lift. Your weight can create a negative pressure close to 0 bara [EDIT ERROR] and you need min 0.2 bara to "lift" the water. Forget weight of either of these things, it's pressure which is the key.
However entrained air in the water will start to bubble out and you don't mention temperature. water will start to boil at reduced pressure dependant on temperature. At 25C its 0.03 bar. Still low but you have very little spare. 30C its 0.042. Also what elevation are you above sea level? Every 100m makes a difference as it is this pressure which pushes the water up the pipe.
As Mr 44 says, you're at the ragged edge here. Any amount of air or vapour and the cylinder will fall, but very little water is drawn up the pipe.
7 m I would say yes[ EDIT - NO WONT WORK], 8m is marginal, 9m no way in practice.
Is this a real question or homework? How do you lift your 3 tonne weight to repeat the pumping?
got any pictures?
Why not use a submersible pump?
