dnflsmsgksk
- Jun 12, 2007
- 4
I am looking at a plant air line with water problem.
The plant air originates from compressors with aftercooler that uses water as a cooling medium.
The plant air line has a pressure of around 93psig and temperature around 70degF.
I have checked drain location right next to the compressors and get no water.
However, at two ends of multiple branches, I get significant water around
1600 cubic inches and 1000 cubic inches of water from 2 minute drain test.
I was wondering if anyone else has looked into a similar problem
and would like to lead me in the right direction to the potential cause of this water. Thank you.
