Water in a refrigeration cycle
MrReds
IT
Hi Everybody,
hope somebody can help me.
I tried to search in old post but without success.
I am trying to calculate some heat exchangers where water is utilized as refrigerant, that is: enters in the condenser as steam and condenses and it is evaporated in the evaporator (enters as water and becomes steam).
Question: can anybody of you suggest me some correlations to utilize for convective coefficient in these two phases for this refrigerant ?
Has anybody of you any experience with water utilized as refrigerant ?
Many thanks
check heat transfer references for convective heat transfer coefficients. There are a lot of published numbers for different water, saturated and superheated phases under different flow conditions.
Yup, that is what they do in LiBr+Water vapor absorption systems.
