When considering the stresses in a self supporting steel pipe with water hammer, can an increased allowable stress be used? This is for the design of a self supporting steel water main designed according to AWWA M11. In other words, I have a section of water main that needs to span a distance like a bridge.
In chapter 7 of M11, it says that for the normal condition the equivalent stress is not to exceed 33 percent of the yield stress. I interpret normal condition to mean the dead load of the full pipe including insulation, lining, water, etc. and the normal operating pressure of the water main. For non-normal conditions, such as water hammer or earthquake, is it recommended to allow the equivalent stress to exceed 33 percent of the yield stress? Again, the material is steel, and we are going to use a material with a Charpy V-Notch toughness of 25 ft-lbs @ 32 degrees F.
In chapter 4 for hoop stress, M11 says that the hoop stress may rise above 50% of yield for transient conditions, but shouldn't be allowed to go over 75% - a 50% increase in allowable stress. Therefore, would it be reasonable to increase the limit on the equivalent stress by 50% for consideration of water hammer effects or earthquake?
