Water demand summary sheet
mitcham
GB
I am working in an HVAC/plumbing consulting firm. The question is if there is a summery sheet available for building water demand per NFPA for various scenarios based on building size (number of system risers), occupancy, type of fire suppression system (wet/dry), building fully sprinklered or not, combined standpipe system and so on. A summary sheet, perhaps with reference to NFPA for each data will be a very useful tool for non-fire protection engineers.
No......way too many factors to consider for each given building/occupancy!
Only qualified people or certified fire protection contractors should be determining this type of data. Mistakes can be costly and the liability is huge.
The info you have requested is like playing with a loaded gun. If you do not know what you are doing you can hurt a lot of people. Best to leave it to folks that know what they are doing.
NFPA has requirements, the International Building Code has requirements, sometimes they agree with each other sometimes they do not. Then states, counties cites have local requirements that maybe above or below nationally recognized standards. Way too many variables to go into for just one sheet of paper. Good question, not an easy answer to it, sorry.
Fire Sprinklers Save Firefighters’ Lives Too' Check out for "Hands on" Fire Protection Seminars
Not ALL Sprinkler Systems Are Created Equal! An Inadequate Sprinkler Design Is JUST As Bad As A Nonsprinklered Building!! When Occupancies Change So Should The Sprinkler System. See NFPA 25, 2002
