Water boiler tube burst 1
Petroleum
Jun 25, 2001
3,433
Some days ago we have had a water boiler tube burst. Burst location was in a radiant rear water tube at the top convection zone on an almost horizontal part of the tube, about 1,5 m from the top water tubes header. First visual inspection of damaged tube was a typical failure of a "thin-lipped" burst of the boiler tube. This type of failure results in a ductile rupture of the tube metal and is normally characterized by the classic “fish mouth” opening in the tube where the fracture surface is a thin edge.
After a closer microscopic microanalysis of the thin edge and good tube zones we didn’t found any differences in the microstructures between thin edge and adjacent good tube zones. No evident distortion of ferrite and perlite was seen.
For that reason we think the failure has occurred well below the lower critical transformation temperature with no evident distortion of ferrite and perlite.
Adjacent tubes don’t reveal any plastic distortion or diameter tube growth. After digital Rx examinations we found that adjacent tubes of boiler tube burst showed great thinning on top of part of the tubes at 12 o’clock location, the thinning was about 250mm long. Nominal tubes thickness is 5.6mm and thinner point in 250mm length was 1.5mm.Thickness of bottom part of the tubes were ok.
Due to the facts my conclusion is: tube failure cannot be explained by a short term overheating.
My question is can we explain the thinning on top of the tubes by cyclic turbulent erosion of wet drops of steam?
Tube goes 15m in a vertical run and then it turns almost horizontal within 2m after connecting with the upper water boiler header. On the vertical part of the tubes there is a equilibrium between water and diffused steam bubbles, but on the horizontal part of the tubes about 1m of the turn bend, by differences of densities the water runs on the lower part of the pipe and the drops of wet steam run turbulently above the water inducing high erosion on that 12 o’clock location of the tubes.
My intention is to warning other operators for this kind of failures and to have comments from the forum on my conclusions.
Tanks
Luis Marques
This sounds like internal wastage caused by a steam blanketing effect during flow conditions through the horizontal boiler tube. This is a damage mechanism I have seen in horizontal roof tubes in a power boiler. The wastage occurs along a narrow band along the top of the horizontal oriented tube.
I don't think the steam is the source of your failure.
Fly ash erosion? Is it a coal boiler?
Reducing environment? Could this area of the boiler be more starved for oxygen?
Gene Grindle PE
I believe the wastage is from the ID side of the tube.
Thank you for your answers!
metengr
I totally agree with you our tubes internal wastage is occurring exactly in a narrow 12 o’clock band on row tubes adjacent to the burst one.
ggrindle
The wastage is internal (water side of tubes) so it cannot be attributed to fly ash erosion.
Boiler burns fuel or fuel gas
Luis Marques
aaaaaahhh
did not get that it was internal ID that was wasting away.
I have no first hand experience with that mode of failure.
If indeed you do have 2 phase flow in this area, that might explain it.
good luck.
0707
I have a question
when did tube rupture?
operiting or start-up
What is the boiler rated for Lbs/hr and what is your actual peak firing rate?
could it be erosion due to over-firing?
I agree with metengr's post of 6/26. You can correct this by using rifled tubing in these areas to increase the turbulence through the tube.
