diggingdeeper
i have a 70' bowstring truss with the 6x6 bottom chord split through the bolts from the heel past the first panel point. the truss supports a mech load above the 1st top chord panel point (1st in from the heel), and there is evidence of water on the underside of the sheathing in this area. the top chord consists of 4-2x6 flat, apparently nail laminated together.
with the break, the top chord has essentially 'lost it's curvature' over that 1st top chord panel point, ie. 'flattening out'.
can you help me understand and quantify the impact that water may have had on this scenario?
