The old fashioned manner was to flush all household liquid wastes to a septic tank, which would then drain to a disposal field onsite. Each state has its own standards for the design of the septic tank and the allowable soil conditions for direct disposal from the tank outlet. The most sophisticated standards I have seen are for NJ.
The first step normally is to test the soil at the proposed site of the disposal field. A 10 ft deep excavation is made to determine the complete soil profile and to determine the depth of the seasonally high water table . The type of soil at each depth is graded, and a sample of soil is sent to a lab to determine its permeability using ASTM testing methods. The old "perk test" is not used in too many states anymore.
If the soil is not adequate for direct drainage of the tank effluent, one has 4 choices:
a) replace the soil at the disposal site with "select fill" of 80% sand and 20% clay, or
b) construct a "mound system" with an elevated mound of sand, and the septic effluent is pumped to the mound using low pressure distribution piping system
c) use the latest technology of a combination bioreactor + microfilter + UF as tertiary treatment and discharge the treated to an accepted mound system or use it for agricultural watering.
d) use a E-one grinder pump and low pressure piping and pipe the effluent to a city sewer within 1 mile, but this requires obtaining city right of way for the piping etc.
"Whom the gods would destroy, they first make mad "
