Hello
I am designing a single story steel frame to support the skillion roof over transportable building (modular building) use for change rooms and toilet amenities. Building will be fabricate including the columns inside the walls and according to structural requirement and will bring to site as a whole unit to minimise site work( roof separate due to height issue , roof height 4m) and use bolted connection at site to fix the roof to column frame.
1. in terms of wall tracings to resist horizontal loads(wind loading) as shown in the doc attached as option 1. Is it a good option to have a truss as shown or do we really need to have this truss bit ?
2. As per option 2 , can we have normal cross bracing without truss bit, even it is unsymmetrical ?,
3. Which option is the better solution for wall bracing ?
4. these modular building walls are 90mm steel stud walls, the columns support the roof will be connect to walls by screw fixing . In this situations can we consider the columns are braced by the walls? then the requirement of wall bracing can be minimise.
Any replies appreciate and thank you for your time
