All our protection and metering equipment uses 63.5/110 Vac secondary (or 120 V in some parts)
In my part of the world, below 50Vac is considered ELV, and 110 V needs to be treated the same as 999 volts.
When I first started out 110 V was considered safe, but times have changed
There doesn't seem to be a lot of equipment you can buy with an ELV nominal voltage.
Are there any technical reasons for this, or is it just because it has always been done this way.
