Suggestion: Generally, the higher voltage levels have smaller short circuit fault levels, therefore, the smaller current interrupting ratings/capability are specified. The lower voltage levels have larger current fault levels, therefore, the higher rated current interrupting rating/capability of protective device is required. Therefore, it is necessary to verify if your higher voltage level fuse has the sufficient current interrupting rating/capability. The voltage requirements are covered by the above postings.
