Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
pmarc said:Also, keep in mind that the requirement for the datum feature simulators to be basically located relative to each other does not apply to cases where secondary or tertiary planar datum feature referenced at RMB has a locational relationship to the higher order datums.
4-31 (b) is even more of a problem as half the profile tolerance zone lies on the far side of the fixed datum feature simulator.
Would it? Suppose the holes are not yet there; the part would first be encircled by datum simulator A, and then rotated clockwise until it hits that stop block. The stop block is indeed 15 mm from datum A, but wouldn't the part simply stop its rotation sooner?3DDave said:If the perpendicular distance is 5.1 from the A datum feature axis to datum feature B and the datum B simulator is 5 from the datum feature axis there will be an interference problem.
Nevermind, I see it now. Had to use my PC monitor.pmarc said:3DDave,
I may be misreading your diagrams, but if I take just the last one, why is the line MJ passing through the horizontal -5?
