Viscostiy of Shortening
rocksolid
Industrial
Can anyone tell me or help me find the viscosity of shortening, lard, or butter that would be in state that I could pump it thru an extruder?
This is not too much immediate help I'm afraid.
Doesn't the extruder manufacturer would know what viscosities he can squeeze?
Re your materials. Obiously there's a temperature factor but I believe these fluids are actually thixotropic, which means that the more you work 'em the thinner they become.
My copy of "Perry" sends me to "Eirich, "Rheology" vol 4 (1967) for "Thixotropy and Dilitancy"".
Perhaps you could try your engineering library.
[smile]
David
Rock, I do believe that shortening or lard or butter is what is called a non-newtonian fluid which can have some rather strange propeties when it comes to viscosity. As for the Non-newtonian properties, see the list:
1. dilatant: viscosity increases at increased shear
2. pseudo-plastic: viscosity decreases at increased shear
3. rheopectic: viscosity increases at time rate of shear
4. thixotropic: viscosity decreases at time rate of shear
Now that I have thourghly confused the issue for you, the tables I've got don't list the medium you're asking about. My suggestion is to contact either Robbins & Meyers Moyno Pump division, they manufacture progressing cavity pumps with low shear properties, and have extensive experience in pumping non-newtonian fluids. Or you might try, Trans-America Delaval, Imo Pump Division they also have experience in progressing cavity pumps and non-newtonian fluids.
Good Luck!
saxon
