hi,
I'm running 2002, and I have a problem when I rotate my viewports in paper space.
If I'm in a layout, and I rotate a viewport say, 90 degrees, if I later take the same viewport and try to return it to normal by rotating it negative 90 degrees, it instead goes 180 degrees. If I then rotate same viewport 45 degrees, it works as expected, but if I rotate it another 45 degrees, instead it rotates 180 relative to the last move.
any subsequent newly created viewport also come in at this rotation, locked into the same problem. very frustrating...
any insight into what's happening?
I apprectiate any help
sundemeon
sundemeon
