Vibration time measurements 1
delfina
I would like to take acceleration measurements on a moving vehicle in order to calculate an approriate PSD curve for an evaluation test. Does anyone have any experience in this area? Any good books to get?
Things I am looking for is
1) instrumentation to use
2) how to avoid aliasing, minimise noise and quantitization errors
3) Window to use when converting time data to a PSD
4) Any helpful MATLAB scripts
Delfina
We've been involved with several DSP-based data acquisition systems for automotive applications over the past few months. Could you provide more information about your application. Do you want to log data and then evaluate on a PC, real-time. Accuracy requirements ??
Feel free to contact me to disuss adaption of one of the existing systems for your application.
Emmet Raftery
CDA Systems Ltd.
(800)280-3972
we are using an adxl250eb analog device accel connected to a DATAQ DI-700 data aquisition system. We would like to measure frequecy content up to 200 Hz. We then would like to collect the time data while device is on a car. After that we would like to calculate a psd ( power spectral density ) using octave( like Matlab) from the collected time data.
I have done similar data collection using battery-powered recording devices from Instrumented Sensor Technology (IST).
Disclaimers:
1. I am not a salesman for IST
2. A number of other vendors offer similar devices
The IST units are available with internal or external accelerometers. The user can specify the anti-aliasing frequency as part of the order. The units are available for sale or rent.
IST also provides post-processing software. I prefer to download the data to ASCII text and use my own program for post-processing, however. This may include shock response spectra and power spectral densities depending on the characteristics of the data.
The P95/50 method can then be used to derive a envelope or test level if a number of power spectral density functions are calculated.
Tom Irvine
Email: tomirvine@aol.com
See Greg Lolock's FAQ for some good links.
An on-line free textbook which is pretty darned detailed:
