TPL,
What is the purpose of building it – is it a commercial undertaking or is it some sort of educational project?
It is not really home-made. An external company has been developing the project but we have been required to solve the mechanical problems. They will work in the elecrics and we will finish the mechanical part.
This doesn't make sense – a natural frequency is a natural frequency. Different components might have their own natural frequencies and the assembled rotor might have several different natural frequencies (1st , 2nd ...etc). What you need to identify is the rotor critical speeds – these are characteristics of the entire rotor.
As I showed in pictures I attached, natural frequencies of the rotor seems to be 2250, 3000 and 7000 Hz. These are the natural frequencies of the rotor itself because are the ones we have found by hitting the shaft with a “hammer”. I have said that the 2250 Hz seems to be the natural frequency of one leg because when I hit with the hammer there this component is the one that is most amplified. When I do the same at the other leg the component amplified is 3000 and when I hit in the middle the component amplified is 7000 Hz. I think that if the problem was from the rotor I should see some peak around 750 Hs. Please correct me if my assumptions are wrong.
How are you measuring the response of the hammer test? What transducer is used? Have you considered that the weight of the transducer might influence your results?How do you know that the response from the hammer impact is from the rotor and not from the support structure. Are you sure that the hammer will excite the rotor natural frequencies?
The weight of the accelerometer is 1.3 grams. I mount it in a small aluminium base. I have done the test in several ways of mounting it. The results are nearly the same. The picture I sent is measuring the rotor when it is hung up with thin linen so there is no support structure response. I’ve hit with a brass hammer because the rotor is magnetic and I cannot use steel. I’ve hit also with a pen and the results are the same.
So just how good are the assumptions/approximations?
They were just to see if the value was similar to simulations. I’ve done calculation using the distance between bearings, the geometry and mass of the rotor.
Who did the modelling? How confident are you that the model accurately represents the behaviour of your assembly?
I did the modelling and it is almost impossible to create an exact model. If I would need to do an exact simulation I would need to simulate carbon fibber and sinteritzed neodymium. The model respects geometry, constrains and so on
ISO 1940 applies only to rigid rotors and is for low speed balancing of rotors in a workshop– at the speeds you describe, you should consider your rotor to be flexible. You need to consider modal balancing which takes into account distribution of the mass unbalance and rotor mode shapes. Until you get this right, the most likely cause of all your problems is rotor unbalance.
This is something interesting I will have a look at ISO 11342. Just one question, If I were ok with hammer test and there was no natural frequency of the rotor within 0 and 90.000 rpm, How would the rotor pass through critical speeds?. Then the rotor will be rigid or I will need to study deflection due to rotation forces? If the shaft deflects, is it possible to experience a change in natural frequencies due to redistribution of mass?. Please, I would appreciate some help in this point because I think that I am misunderstanding something…
