GregLocock
Automotive
OK you've got some instrumentation. The plots aren't very helpful are they? You need to look at the vibration each side of each isolator, and look at the transmissibility across the mount.
Then you need to start building a system model, at least in your mind if not on paper. As Tmoose implies, a modal approach is the most straightforward way. You can use forced response (ODS) data instead but it will lead to puzzling results like softer mounts giving more vibration.
Cheers
Greg Locock
Cheers
Greg Locock
