mechatronic
Hi!
In a recently procured Hydraulic Pack, Vibrations are observed.
It is a motor driven rotory pump. Motor is fixed on a base plate while pump was originally hanging like a cantiliver - now supported from the bottom
The Axial Vibration monitored is about 8 mm / sec while on lateral Axis we found a Vibration of 3.3 mm / Sec
The pump is directly coupled by a flexible coupling to the drive.
1. Could any one tell if there are any standards which defines permissible levels of Vibrations ( I Mean is the above mentioned vibration levels are Techically acceptable? )
2. Client is not happy with the Axial Vibrations - what could be the solution - Vendor says he wants to support the pump from sides also ( left and right side while looking from the motor end )
3. Coupling is a flexible one - what could be the problem ?
4. I am not happy with the vendors solution
Can any one guide me on Vibration levels permissible and possible solution
