MDjajasaputra
I need to do vibration analysis for dancing and concert. Attached is my problem.
Structure consists of the following
- big trusses at lines A and B (L span = 6x28ft) with support at line 1 and 7.
- 7 columns at line C
- 7 lines of trusses spanning between big trusses and columns at line C
- Floor loads supported by filler beams and then transferred to trusses.
I'm thinking to simplify my problem assuming a bay of 168ft (= 6x28ft) by 70ft with trusses at line 1 to 7 as a beam and big trusses at line B as girder. I will follow the design guide 11 procedure with these assumptions. Is this the right approach? Need some inputs. Thanks.
