Well, we accept that the term VFD can only refer to AC motor controls, so frequency is speed when implemented in the motor. The VFD also has to change voltage at the same time, and of couse the output pattern determines direction of rotation, but none of those can exist without the other. So VFD (as related to motor control) always means variable speed even if not stated. AFD means the same thing, but VFD is a more popular term.
VSD (as well as ASD) is actually a more generic term. It can mean a DC drive, an eddy current drive, a fluid drive or a mechanical variable pulley system such as a VariDrive or Variator. People use VSD quite often, but they really should probably be more specific since it can and does mean many things.
Inverter is another problematic term used a lot for VFDs. Technically, all VFDs have an inverter in them because that is the heart of the technology, but there is also a converter at the front end, and there are also plain inverters that are NOT VFDs. So again, it is technically too vague.
Side note:
To make matters worse, especially when searching the internet, VFD also means Vacuum Fluorescent Display, Voluteer Fire Department, Variable Field Data and a host of other non-motor related terms. Makes life interesting.
"Our virtues and our failings are inseparable, like force and matter. When they separate, man is no more." Nikola Tesla
Read the Eng-Tips Site Policies at faq731-376
![[pirate] [pirate] [pirate]](/data/assets/smilies/pirate.gif)
Member, [blue]P
3[/blue]
