Our customer initially ordered a VFD based test stand. Electrical dynamometer motors operate only in power absorbing mode. The 4-quadrant VFD (with PWM IGBT based front end) was expected to regenerate the shaft power (about 3 MW) back to the grid. The problem occurred when the customer failed to receive from utility a permit for co-generation of power. Now under consideration is a possibility to dissipate that energy via large load bank. One of suggestions was to create a large DB resistor system (like in non-regenerative drive) tapping the DC bus. Other suggestion (by drive MFG) is to use existing front end converter for regeneration of power into AC load bank. Question to community: is this something for real? Common understanding is that one needs front end converter in regen mode synchronized by the grid voltage and frequency. Is this possible to route the shaft power through front end converter into AC load bank ? Reference to any published materials on the subject would be greatly appreciated.
