I'm designing a facility that has several 150-250hp pump motors on VFD's. The distance from the VFD's to the motors is less than 50ft. The motors will be inverter duty rated. The cables can either be armored cable with 1000V insulation, VFD cable, or individual wires with 1000V insulation.
I've been told that we should include output reactors as "cheap insurance", but the drive manufacturer does not require them for this short distance.
The way I see it, the reactors will help with motor efficiency & motor temperature even if voltage transients & insulation stress aren't an issue. Opinions?
