I'm using a MA7200 to run a lathe motor. The original motor was a 3hp. This one is a 5hp VFD motor. I have everything working fine except the deceleration is anemic.
I've set accel and decel to 1 second. The motor ramps to 1720 in one second but refuses to decel in less than about 4 seconds. I have a mondo load resistor that doesn't rise above room temperature (which is saying a lot since it's ^*#@^%! 45F).
Running it in sensorless vector.
I've tried "Full Range" DC injection braking with only trivial improvement.
When STOP is commanded the current changes from about 5A at full speed with no load, to 7A on its leisurely stroll to zero.
Conversely when I switch instantly from full speed forward to full speed reverse the VFD dumps 30A into the motor and has it running full speed reverse in about a second.
I'm sure it's one of those cases where some quasi-related parameter is limiting the maximum stop current but I can't find it after more than an hour of weeding thru the manual and trying everything even remotely suspicious.
BTW: Never once have I had a single fault so it's not like it physically can't decelerate as fast as I'm asking it to.
Here's the: Manual
Keith Cress
kcress -
Here's the: Manual
Keith Cress
kcress -
