One of the important nominal base settings for the VFD is the base frequency, which is typically 60hz or 50hz depending on where you are in the world. You need to have the motor frequency and voltage set properly in a VFD. Then, the VFD can produce the proper V/Hz curve to match the motor.
Now, the rpm setpoint could be either just for display or it could be used to set the nominal frequency. But, it's not likely to be used to set the base frequency because then you'd also have to enter the slip and the motor poles to get the right base frequency calculated. So, to get the right base frequency would require correctly setting 3 parameters which is a poor method for obtaining such an important motor parameter. But then, using 1800rpm/4-pole would give the same base frequency and V/Hz ratio as using 3600rpm/2-pole.
