Gentlemen,
We are ordering a VFD system (PWM based, with active front end/regenerative) and need to ensure drive and motor compatibility, since they are provided by different vendors.
Drive vendor states that for the system with common DC bus and more than one inverter/motor, each of multiple motors will see on its terminals voltage spikes increase about 50% (peak value) more than it would have for single inverter configuration. In their opinion, the reason for this increase is a common mode voltage brought into drive via motor feeders and, related to that, the increase of voltage spikes level on DC common bus. Based on that, they require that the motor insulation must be upgraded to handle these additional spikes due to multi-motor configuration. This puts a burden on motor vendor. In numbers: drive input voltage is 480V. Motor insulation is designed per NEMA MG-1, part 30 to withstand 1600V spikes (for inverter duty motors). Now, drive vendor claims that each of motors must have insulation rated for 2400V if both motors will be fed from the same common DC bus drive (via separate inverters, of course).
Questions to VFD experts: have you ever heard about this phenomenon? Is this possible that these claims cover up drive design deficiencies and put unnecessary burden on motor designers? Any links to information to better understand the issue?
