I have to design a 10” diameter ASME VIII div.1 vessel containing hydrogen, with design temp. of 500°C and design press. of 20 barg. I should use 304H stainless steel but it’s hard to find this material on the market. A supplier propose 304/304L as an alternative material. Can be this solution correct? Which material can I use for this application? Is the 321 stainless steel suitable for this application?
