Greetings, I am currently designing a moment connection between an HSS column and an HSS beam, I am forced into this configurations and although I would very much prefer to use W-shapes it is out of the question. Initially I tried to simply weld the beam to the column, but this lead to a myriad of problems such as plastification of the column wall, punching of the column wall and such. Currently I am trying to use stiffening plates to keep the wall of the column from deforming. However I know of no hand calculation to design or even estimate the design of this connection, this led me to rely on a FEA program (SAP2000), which I very much dread since I have to rely completely on the computer. What I did is model the connection without the siffeners and check that its behavior is as expected (miserable failure of the the connection to behave as fixed) and then I proceeded with my stiffener plates scheme. The general behavior of the connection is as expected, the HSS walls are no longer deforming as the plates give them considerable resistance. I am seeing very high stresses near the corners of the plates.. But this is a linear FEM Analysis so no stress redistribution after yielding is being accounted for. I will attach Images and printouts of the connection and would very much like to hear your input, If anyone can suggest a method for hand calculation I would greatly appreciate it.
