Hi, I am a young engineer still trying to get a good handle on GD&T. I have a basic understanding of it and can interpret just fine, but have a question regarding basic dimensions. Every example I have seen for true position gives the basic dimension of a hole location from the referenced datums and this makes it very easy to understand in this case. Suppose the basic dimensions don't refer back to the datums though?
For example, consider a square part with a hole and each side of the square have a dim and tol. Datum A is the face the hole is drilled into, datum B is the right face, and datum C is the top face. The hole has a basic dimension from the right face and from the bottom face and the TP of the hole is called out wrt ABC. Can this dimensioning be done or is it nonsense because the location of the hole is not specified relative to datum C (top face) via basic dimensions only. Not saying I would do this, but could I?
Put another way, must a feature be located relative to the referenced datums using basic dimensions only? When we use the FCF we are saying that the position is to be checked relative to the datums, but do the basic dimensions need to specify the location relative to the datums as well?
