Vertical Multi-Stage Pump
OliverSudden
3
I am looking for a vertical multi-stage pump for the duty of Flow 97.2 Lts/s, 82m Head.
I can't find one from the usual sources, anyone came across one of these monsters?
Do you mean a vertical turbine / well type pump, or a vertically mounted, in-line type pump?
Based on what you've provided, Goulds would have several choices.
For multi-stage centrifugal that is a fairly small pump. Any of the submersible pump guys should be able to do it.
Plymouth Tube
The type of pump we are looking for is actually an inline multi-stage pump, not a submersible. We currently have an end suction on this duty, but guys on plant want to change to this type.
Anyone know of a manufacturer that makes this type of pump to this size?
I believe that the Goulds(Vogel) MPVN is what you're looking for - depending on where in the world you are, they may be able to do this high flow.
Certainly, there would be others. I would also check out Travini (sp?), SIHI, etc.
