1gibson:
Yes, that was what I was trying to explain, in a poor fashion. It is based on a "once upon a time" experience that I had years ago with a vertical in-line condensate stabilizer reflux pump. At a certain percent open on the reflux pump discharge flow control valve, there was a significant drop in throughput to the column that I read using a Polysonics Doppler Meter. There wer no audible signs of cavitation, and at the flow setting coincident with column pressure, there ought not to have been a capacity problem. When I (with the Operator) opened the pump casing drain to qualitatively assess the nature of the liquid, we found that it was rapidly boiling off even when we dumped a 45-gallon of Northern Alberta January snow on the suction piping. What I decided to do, right or wrong, was tie a restriction orifice / needle valve / tubing installation from the casing vent back to the reflux drum vapour space, with a view towards being able to allow any broken-out vapours to be expelled. This change, after a suction piping optimization and the installation of a flow-inducer imeller in the pump, provided enough incremental performance improvement to achieve the desired reflux rate.
SNORGY.
