Jul 13, 2015 #1 mangocanh Petroleum Joined Sep 4, 2014 Messages 6 Location VN Hi folks. I would like to have a query why Venturi is usually used for compressor suction and discharge? What is its advantage and disadvantage? Thank you.
Jul 13, 2015 #2 europipe Chemical Joined May 14, 2007 Messages 710 Location NL Please show us the application and the PID. Mostly there is no venturi there. Do You mean a reducer? Upvote 0 Downvote
Jul 13, 2015 Thread starter #3 mangocanh Petroleum Joined Sep 4, 2014 Messages 6 Location VN I mean Venturi flow meter Upvote 0 Downvote
Jul 13, 2015 #4 Latexman Chemical Joined Sep 24, 2003 Messages 6,952 Location US Low non-recoverable pressure drop. Good luck, Latexman Technically, the glass is always full - 1/2 air and 1/2 water. Upvote 0 Downvote
Jul 13, 2015 #5 pennpiper Mechanical Joined Dec 9, 2005 Messages 1,687 Location US That is a Venturi Flow Meter not just a Venturi. It is one of the best and safest methods to measure and record the flow in a compressor line. Sometimes its possible to do all the right things and still get bad results Upvote 0 Downvote
Jul 13, 2015 Thread starter #6 mangocanh Petroleum Joined Sep 4, 2014 Messages 6 Location VN Thanks folks for your answers. Hi Pennpiper, Could you detail why it is one of the safest methods. Is it the safety reason? Thanks in advance. Upvote 0 Downvote
Jul 14, 2015 #7 pennpiper Mechanical Joined Dec 9, 2005 Messages 1,687 Location US If you check with a Venturi Flow Meter supplier I think you will find out there are no internal parts to break off and cause damage downstream. Sometimes its possible to do all the right things and still get bad results Upvote 0 Downvote
Jul 15, 2015 Thread starter #8 mangocanh Petroleum Joined Sep 4, 2014 Messages 6 Location VN Thank you very much Upvote 0 Downvote
Jul 16, 2015 #9 Chemitofreak Chemical Joined Jan 29, 2008 Messages 40 Location NL As Latexman said venturi is used because it offer less pressure drop as compared to orifice. Dinesh S SHELATKAR Process Engineer Upvote 0 Downvote
