These may be too general questions but I will give it a go.
What would be considered the normal spread of values obtained between the 3 Charpy specimens in a test?
Does the expected variation depend upon the overall level of toughness eg 10J vs 100J?
To define a little further, the case in point deals with a 410 type stainless steel quenched and tempered to approx 235 BHN hardness, 105 ksi YS and 115 ksi UTS. There is a longitudinal charpy requirement of 20J min at RT.
There appears no issue obtaining the requirement. Results exceed 100J. But what has been observed (and has raised questions) on a number of tests is that 2 of the 3 specimens are closer together (10-20J difference) and one specimen is marked different, usually lower by an order of magnitude from 20-50J.
The specimens are extracted from a 4" long samples cut from a tubular forging whose cross section dimensions as heat treated were 8"OD X 4"ID. The longitudinal specimens were extracted beside each other in an "arc" at approximately mid-wall.
Any comments would be greatly appreciated.
Thank you.
Thank you.
